Difference in Playnack mode and in export session to csv.
iroczinoz
Post by iroczinoz »
Mangus,
Quick question. I guy sent me his aldl log. It is very weird we are thinking maybe a bad ecm.
Anyway though. When you play back the log file in tunerpro RT it kind of shows up alright values but they are skewed.. But when I export the session to CSV format the data is cut off where this only 50 or so samples. And the numbers are like in the negative range etc...
What I am trying to say is that the CSV to playback mode is completely different.
Have you had any issues with this?
Another thing while I am here is I wanted to ask about the closed loop flag. You mentioned to me that you have to set it in the ADS. I have done that it is set to viewable but it still does not show up in the log. I must be doing something wrong.
I would gladly send you the aldl log file for you to see what I am talking about.
Are you using the correct ADS file to view the log?
Regarding the loop flag - flags aren't outputted in the CSV.
