Monitor window does not display logs
toliphint
Post by toliphint »
All of a sudden, cannot view a log on laptop with TP RT v5. All data display windows in the Monitor window are blank (no lines). Same xdl log file put on a thumb drive is visible and runs as it should on desktop with same TP setup. Both are same Win7 versions and ADX files are same via a compare. No changes to either computers as updates are disallowed. Interestingly, on the laptop that will not display a log, the slider bar is missing at the bottom of the monitor window. Any ideas? Have rebooted, reloaded etc.
84Elky
there's a *.xdlcache file in your c:\users\all users\RusnaMark\ folder. Delete that and then re-open the ADX and XDL. See if that gets you running.
toliphint
Post by toliphint »
Mangus wrote:there's a *.xdlcache file in your c:\users\all users\RusnaMark\ folder. Delete that and then re-open the ADX and XDL. See if that gets you running.
Bingo- Thanks Mark! All now OK. BTY - File in C:\ProgramData\RusnaMark
84Elky
