Did a LOT of little changes to an ARAP bin.
Fans, ignore EGR, spark tables, fuel calc's etc.
One of the changes I made was to bring the idle up just a little, because of the injector size that is not working well. Went back to tinker with the idle tables some and it won't edit the tables. I change the IDLE vs COOLANT TEMP: 650.00 to (anything below) and tell it save, it won't save.
Got to looking at the info on the bottom of the window for the table and I now see
SEL COUNT: 1 MIN 650.00 MAX 650.00 AVG 650.00
and nothing I can do will change that?
I re-opened the original BIN; was just going to go through and do a compare and such, but new bin will default to 650.00 no matter what number I put in there.
Is there a cache that is bugging me? etc..?
(PM me an email addy if you need, and I will forward the bin (No its not write protected, already checked))
Table is now locked and I cannot edit it
vxl67getrag
