Tunerpro showing all zeros
Chinogaston
Post by Chinogaston »
Good day to everyone..
Im trying to learn how to tune Ducatis using Tunerpro and have succeeded in downloading a bin file from my 59M ECU used in my 2001 Ducati S4. Ive also downloaded the xdf file from Guzzidiag to use with my bin.
When I load the files in Tunerpro however..all the values in the tables are zeros.
What am I doing wrong?
Many Thanks
Have you opened the bin file in a hex editor program to check whether it is a valid read?
FreQRiDeR
Post by FreQRiDeR »
Check the xdf offset in header is correct. Also look at the bin in 2D/3D window to make sure the table addresses are correct. I've had to change these from the guzzi xdfs as the ducatis are a little different.
