Copy/Paste of Table Values Garbles Tables
The Ghost
Post by The Ghost »
I am copy/pasting entire table values (18x17) and when I paste them, it partially works, but then some cells get more than one value and the whole table them becomes wrong.
I am migrating from one tuning platform to TunerPro, but don't want to manually key each cell of the 120+ tables of my custom tune.
Here is a sample of the data being copied:
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 14.596 14.596 14.596 14.596 14.377 14.083 14.083
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 14.596 14.596 14.377 14.126 14.111 14.083 14.083
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 13.799 13.799 13.799 13.501 13.501 13.501 13.501
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 13.799 13.799 13.799 13.501 13.501 13.300 13.300
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 13.799 13.799 13.501 13.501 13.501 13.092 13.092
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 13.799 13.799 13.501 13.501 13.383 13.002 13.002
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.596 13.799 13.799 13.501 13.501 13.002 13.002 13.002
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.596 14.399 13.620 13.261 12.949 13.002 13.002 13.002 13.002
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.596 14.524 14.277 13.322 12.859 12.662 12.787 12.787 12.787 12.787
14.671 14.671 14.671 14.671 14.671 14.671 14.671 14.610 14.341 13.796 12.927 12.636 12.518 12.644 12.744 12.744 12.744
14.671 14.671 14.671 14.671 14.671 14.671 14.671 13.552 12.744 12.428 12.138 12.138 12.138 12.500 12.744 12.744 12.744
14.671 14.671 14.671 14.671 14.671 14.671 14.671 13.541 12.726 12.410 12.116 12.116 12.116 12.500 12.744 12.744 12.744
14.671 14.671 14.671 14.671 14.671 14.671 14.449 13.444 12.676 12.378 12.102 12.102 12.102 12.500 12.744 12.744 12.744
14.671 14.671 14.671 14.671 14.671 14.671 14.373 13.390 12.640 12.349 12.080 12.080 12.080 12.256 12.744 12.744 12.744
14.535 14.535 14.535 14.535 14.535 14.535 14.158 13.257 12.572 12.303 12.055 12.055 12.055 12.389 12.744 12.744 12.744
14.312 14.312 14.312 14.312 14.312 14.312 13.936 13.121 12.500 12.256 12.033 12.033 12.033 12.163 12.744 12.744 12.744
I've had something similar happen with tinytuner.... the issue is that tinytuner was inserting a lot more data into the clipboard than what it needed to.
I found that you can just paste what you do have copied into a spreadsheet, then recopy only what you need to go into tunerpro and you're good to go.
The Ghost
Post by The Ghost »
That worked like a champ, thanks!
So the issue is with the data copied by the source editor?
The data you included in your post looks like it should be fine. I don't see how it would lead to multiple values per cell, as long as the cell delimiters in the data is consistent.
The Ghost
Post by The Ghost »
I am not sure where the problem is. I was copying from Cobb ATR to TP. When I paste into notepad it looks clean as above. Pasting into and copying out of a spreadsheet seems to work.
