hit tracing doesn't work on some eproms / bosch digifant 1
plex
Post by plex »
Hi,
I have ostrich 2.0 on bosch digifant 1 (with GrauTec adapter) on my Corrado and the latest RT version 8519.
Noticed, that hit tracing doesn't work on early eproms such as vw6092 (with g60-1-ignition xdf), but works with late bin vw6636 (3-ignition xdf).
There is a message Waiting when trying to use hit tracing on vw6092 and nothing changes.
Would you please so kind to check it? I can send you the bins if needed
Thanks in advance,
Alex
Search around these forums on tracing. You'll find that it won't work everywhere, in every table, for every vehicle. It can be rather sensitive to access patterns, speeds, and other things along those lines.
bernhard
Post by bernhard »
why do you use a grautec?
ostrich 2.0 alone should be enough?
