DME 3.1 e36 325
Posted: Sun Jun 01, 2014 5:02 am
by maxout
Gets this with new chip:
E R R O R M E M O R Y
Datum: 01.06.14 15:22
ECU: DM331K20
JobStatus: OKAY
Variante: DM331K20
RESULT: : 3error in error memory ! !
26 Control unit Permanent supply
Error counter : 0
Check byte 239.00 [1]
Check byte 235.00 [1]
Hexcode=1AA4EFEB00 0.00 [HEX]
Open circuit
Fault stored after de-bouncing delay
Error not present
Sporadic error
100 unknown Output fault
Error counter : 50
Engine speed 80.00 1/min
Load signal 1.50 ms
Hexcode=6462021E32 0.00 [HEX]
Short circuit to ground
Open circuit
Error present
Static error
37 Relay Lambda probe heating
Error counter : 49
Engine speed 1360.00 1/min
Load signal 3.70 ms
Hexcode=25B8224A31 0.00 [HEX]
Open circuit
Invalid working area (Plausibility fault)
Exhaust gas relevant fault
Error not present
Sporadic error
New ecu or what?
Posted: Sun Jun 01, 2014 6:26 am
by maxout
restored ecu with error start up again and it is static
Error counter : 50
Engine speed 200.00 1/min
Load signal 1.50 ms
Hexcode=6462051E32 0.00 [HEX]
Open circuit
Error present
Static error
Posted: Sun Jun 01, 2014 9:41 am
by maxout
100 Amplifier 1 in DME Control Unit
Read more at http://realitypod.com/2012/06/bmw-compl ... fcZGstd.99
what does amplifier 1 do?
