I'm starting to look under the skirt of my 848 EVO
I was able to catch the bin with IA5Wreader, and it looks like the xdf to use is more like StreetFighter's one (v1.28 ), rather than 848's one.
The first step I tried was to modify display text (wow, what a tune!
So what should do this flag "exvl" in the SF xdf?
The second (bigger) step will be to drag maps values from the DP ECU (ddg file...) into my bin. What should the the keys to check if I did it well before upgrading?
I found another xdf here, but either I think there are interesting things to catch in it (fans t°, immo), I guess there are mistakes (fuel offset, main ignition, Idle trim)
Here's my original bin and the 'unknown' xdf for pros
https://www.dropbox.com/s/spea4uyecf7k0 ... VO_bin.zip
Thanks for help
