When I'm viewing a bin using the built-in hex editor I can see the ascii representation in the right column. How can I display this ascii value as a table (or constant) item? For example, let's say the values at 7000-7004 are:
48 45 4C 4C 4F
When I open the table item which points to this location I want to see this for the output:
HELLO
If I choose "hex digits" for the item output I see 48 45 4c etc., and if I choose "string" I see blank cells. Is there a way to display the ascii equivalent of the hex data?
Mangus wrote:There isn't a way of doing that, unfortunately. Can I ask why this would be important?
Ford embeds strings into their bins I bet, huh?
Actually Nissan does The prom ID is stored in ascii. The request is more of a novelty, the ascii data has no importance from a tuning aspect, I was trying to eliminate the use of the hex editor. I was just surprised the hex editor could do something that the tunerpro interface couldn't. Thanks for the info, I'll just use the hex editor when I want to look at that stuff.
Totally a reasonable request. I'll consider adding it!
Just to revisit this topic.
Would be useful in some of the later model GM bins as the VIN is stored in ASCII.
So once again, any chance of getting this added?
Mangus wrote:I'll throw something together to enable this.
I also need ASCII data type for updating chip signature and version info.
I saw you have a 'data type' STRING but it seems to do nothing? What exactly is 'data type' STRING used for in a table?
Create an XDF table and select "ASCII String" as the output type. Set the number of rows or columns to match the number of characters in the string, and set the address to where the string starts in the bin. That should result in a table of cells each containing an ASCII character in the string.
