.Bin 403 dme
Posted: Wed Feb 19, 2014 3:01 am
by FXX
As I was making my way through the several maps in the definition file I found on this site, comparing similar m50b25nv ecu's (403, 405) it left me wondering what these files are. Are they stock .Bins, or slightly improved files? And are the Bins for 403 and 405 interchangeable?
Def. files I have used:
BMW_ecu403_soft950.xdf, BMW_dme405_soft951.xdf (basically the same maps)
Bins I have compared:
403_3NV_950, 403NV, 405_1740352_1267357951
My journey to a slightly upgraded eeprom has just started, and there's still a lot to learn. For now, budget is limited. In the future, I'd like to implement a .bin switch, but first things first.
Hope to see some useable input from other BMW enthusiasts
Posted: Mon Mar 10, 2014 1:03 am
by aboutton
402 and 404 are interchangeable
403 and 405 are interchangeable
i have done lot of work on 403 and 403 so if you need any help that is not time consuming i will be glad to help.
Posted: Thu Oct 09, 2014 7:05 am
by mexanico
aboutton wrote:402 and 404 are interchangeable
is possible to use a 413 in place of those ecu"s !
how can I use emulator inside of that monotric ecu"s ?!
thank"s in advance
BR
