Problem with Tables...
DarkDevilMMM
Post by DarkDevilMMM »
Hi, no matter what I do or try, I just can't get the table to work, I have couple ECU files available, one of which is my own ECU dump. I can get the values fine with using "constant", but when I input the exact same address into the table format it reads 0000 all across, no matter what I tried, please advise, thanks a lot.
A bit more info please, which ecu, xdf etc.
Look in the XDF header (Ctrl + F2) and make sure the bin size is set to match the size of the bin you're trying to view.
DarkDevilMMM
I left out the bin size, I didn't know that need to be set, thanks a lot!!! I know it's always something about me being stupid.
