I have a celebrity eurosport with a 2.5 4CYL motor that runs rich it Idle. I would like to log data to see what goes on in the belly of the best. I ran TunerPro and set the comport to 3 to match the hardware. loaded ablt673048.bin and $48.xdf. Cable checks good. when I click the arrows to load data nothing happens. It keeps connecting. What am i doing wrong?
Thanks for any help I can get.
Ok
I downloaded a055 with ads extension. I imported def to adx and loaded. no connection. I found a vr_$11_vi.01.adx and I get connection but no data with key on or running. I tried both with and without 10k resistor. I least I saw a dashboard. Closer than I was yesterday. I don't need the bin and xdf to see data right?
Thanks for the help on this. This is fun if I can find the right adx. well it looks like a055 is not the one. I tried $70 with a nogo. I will search the sites for somemore and try as I go.
Thanks again
I found a post about a celebrity logging problem from a user called 88chevyceleb. EagleMark sent him a file that fixed his problem, but he did it off line. I sent a message hoping he can send it to me. I hope it is the adx file giving problems. Well it is dark here in slidell Louisiana and all I need is blow a ecu in the dark. I will try tomorrow morn.
Thanks for sticking with this rookie and trying to get me going.
