Bluetooth on Ostrich V2
maxim
Post by maxim »
I install a bluetooth module to ostrich V2 emulator.
how can I connect it with tunerpro software?
Bluetooth stay com port
like com12 or com5
this is a virtual serial port
tunerpro no any com port adjustment
its give "no emulator found" error
*Tunerpro working with usb cable ofcourse.
->edit for wrong grammar.
Hindra
Post by Hindra »
Slightly off topic, how difficult would it be to port tuner pro over to a tablet or phone? If we can connect to the ostrich2 via bluetooth no cables and tablet tuning would be interesting. I dont program so I have no idea how difficult it would be. Just a thought.
Post by Six_Shooter »
I haven't connected via BT in years, there always seemed to a longer delay for upload verification that seemed to cause more errors than when using a USB cable. I quickly tried a few weeks ago to connect via BT, but didn't give it much effort, I think there was a setting change that I'm forgetting about to enable it.
The Tablet and portable question has been asked and suggested for years, according to Mark, it's just not going to happen, at least for anything other than a full Windoze based OS. A tablet running Win8 should be able to run TP, but I have not tried it myself to confirm that.
maxim
Post by maxim »
I try again connect with bluetooth.
please could you someone tell me what is the serial port baudrate?
when tunerpro connect ostrich v2 with usb what is the baudrate?
(osctrich use FT232RL usb to serial connection chip)
Im try over bluetooth 9600 and 38400 bps
no connection
tunerpro check hardware and didnt connect to bluetooth module
bluetooth port com10
I can change bluetooth speed
maxim
Post by maxim »
Im found it
it use 960.000 baud (not 9600)
Im try use 921.600 baudrate over bluetooth and tunerpro connected.
but not very stable
sometimes line lost
download bin to tunerpro okay
but tunerpro to emulator very diffucult
maybe need very good quality bluetooth devices
For my own AutoProm, which functions essentially the same as the Ostrich, I exclusively use Bluetooth, so I know it works. I believe the module I use is from BlueRadios (the ones Moates used to sell a few years back).
I have not tried Bluetooth with the Ostrich.
Edit: Just chatted with Moates. He said Bluetooth works with the Ostrich. He recommends a Elechouse module.
maxim
Post by maxim »
could you ask again please?
which one ?
http://www.elechouse.com/elechouse/inde ... gaj3fmd4n6
hotrodssnova
bluetooth
Post by hotrodssnova »
I would also like to know. Also in the first picture, are the pin outs correct?
maxim
Post by maxim »
yes pinouts correct
*Mark, Im waiting your help already
thank you
Craig says this one should work:
http://www.elechouse.com/elechouse/inde ... 03rlfq0qt5
Note that you'll likely have to configure it, so you'll need the appropriate hardware (USB/TTL) to send it the proper AT commands to do so. I don't have experience with it myself, so I won't be of much help.
hotrodssnova
bluetooth
Great info. Thanks!
