XDF for UK Calibra v6
Posted: Wed Mar 06, 2013 9:20 am
by Turbosport
Anyone got anything for this ECU no matter how rough ?
Vectra 2.5 litre V6 (C25XE) 95 Bosch Motronic 2.8 0 261 203 080 90 357 990 XEBM3080
Also anyone knwo where I can get the original BIN from ?
Cheers
Posted: Wed Mar 06, 2013 10:02 am
by Mangus
Moved to Bosch forum.
Posted: Wed Mar 06, 2013 10:03 am
by Turbosport
Thanks Magnus
![Smile :)](./images/smilies/icon_smile.gif)
Posted: Fri Mar 08, 2013 9:33 am
by DmcL
first of all your ECU is 0 261 208 080, the rest of the numbers/digits probably wont be of any importance. you can try searching for a bin file and/or xdf for that ECU number for a start. if all else fails you would need to read the chip via a willem reader/programmer and then find/figure out the maps in winOLS then make an xdf from your findings. bit of a tall order if you arent in any way familiar with how these ECU's are coded though.
Posted: Fri Mar 08, 2013 6:08 pm
by festy
I'm guessing that the 357 990 refers to the chip code - I don't have that bin, but I do have 1.267.358.299 which is a Calibra 2.5 bin for the 0.261.203.080 ECU.
PM me your email address if you'd lke a copy.
Or, you should be able to read the bin out via the diagnostics port. It's slow, but saves pulling the chip.
Posted: Mon Mar 11, 2013 2:59 pm
by DmcL
357 990 may be chip/software number.. hard to know unless you check and its in the code of the bin file somewhere or on a label on the chip. bosch software numbers (for older motronic anyway, not sure about newer) are always 1 267 XXX XXX.
you may be able to use a different bin/software version for the same ECU.. i cant say for sure but i know with older BMW motronic you can swap chips/software versions.
