DFCO settings on a 93 lt1 corvette w/ $DA2
dizwiz24
Post by dizwiz24 »
I wanted to ask about where my DFCO (deceleration fuel cut off) settings should be at for best performance (smoothness and fuel economy).
I have a bunch of scalars and tables for this on my $DA2 definition file.
I have:
DFCO enable RPM
DFCO disable RPM
DFCO enable MAP
DFCO disable MAP
DFCO diasble RPM decrease threshold
DFCO enable coolant temp threshold
DFCO enable TPS threshold hysteresis
For the tables I have:
DFCO enable TPS threshold vs. RPM
(currently set around .78 to 1.2% threshold from 0 rpm to 3600 rpm)
Any help on optimizing thse settings is appreciated.
The car is a 93 supercharged corvette lt1 with zf6spd transmission, 60 lb/hr fuel injectors, headers, cam, heads, ostrich, etc.
Are you having DFCO-related issues that you're trying to tune out? Generally, DFCO should be set up to engage when you're completely off the throttle under pretty much all conditions above a certain RPM threshold (e.g. 1200 RPM), with a bit of hysterisis between engage and disengage. Most likely the stock settings are correct, unless you've changed out your load-sensor setup (MAF/MAP), in which case you may need to change the load-based enable/disable settings.
But basically, enable above 1200, and remain (disable RPM in your list) until 1000. Set the load settings only as light as is needed for off-the-throttle enablement of DFCO.
dizwiz24
Post by dizwiz24 »
Ok this is good info as my dfco is set to engage below 1200 rpm, which you advise against.
I can zero that out.
People on other forums say I should just zero the whole dfco out to eliminate it entirely
i don't use DFCO so much for fuel economy gains (though there is some to be found if you drive in the right situations often enough), but i use it more for engine braking to save on the actual brakes.
decipha
Post by decipha »
Also worth noting, dfco can cause the wheels to lockup if you have a locker rear end at high speeds
Had it happen once coming through the traps, back wheels locked up and the car went sideways at 145+ mph, thank god the driver survived with minimal injuries
In any case I always put a 3 second delay at CT before allowing dfco
