Is there a way to set-up V5, so that I can have two instances open, with different bins, or even code, and switch the emulator control between them?
Tonight on my bench I was testing a certain code with one ECM, it started to show some problems that I couldn't seem to correct by uploading a stock bin to the emulator, so I swapped to a different ECM to test, but had to close the original instance of TP RT V5, before the second instance would recognize the emulator. When I went to switch back to the other ECM and code, I had to do the same, close one instance before the other would recognize the emulator.
The emulator is a Moates Ostrich 2.0 BTW, Firmware: v20.9.0
Switching between instances...Emulation
Have you tried to "Release Emulation Hardware" (under the "Tools" menu) in one instance and then "Initialize Emulation Hardware" in the other? I'm just guessing this might work.
- Six_Shooter
Actually no, I didn't try that, I forgot about that function, because it doesn't have a button in the tool bar.dfddfd2 wrote:Have you tried to "Release Emulation Hardware" (under the "Tools" menu) in one instance and then "Initialize Emulation Hardware" in the other? I'm just guessing this might work.
