hi
V5 + Ostrich V2 + IAW 4W6 weber ecu (27C256)
I can trace on injection map real time
but ignition map not
have any idea about it ?
thanks again
no trace on ignition map
This may be a similar to Digifant 1. The way the eprom is connected, it doesn't provide a good enough signal for data tracing to work properly, (socket booster didn't help) Grautec from germany figured out the issue and made an adapter to fix the problem. I don't know if this would help in your case because the circuit board design needs to be analyzed. On Digifant, I was able to hit trace a 256 byte table at $4000, but not one at $4100 without the adapter.
If you are just trying to tune the ignition and fuel maps, then I would suggest using a wideband to input the RPM and MAP value to TunerProRT via an ADX definition. Then you can use "data tracing" instead of hit tracing. I use my Tech edge wiideband to do this.
