I have a 1989 Iroc with a 350. Only mods are headers and custom dual exhaust, AIR removed. AFS-74 3-wire O2 installed.
I am new to tuning these engines and would appreciate any help you all could give.
I have looked on various forums and tried everything I have seen to fix this problem and nothing seems to work.
I am using Tunerpro RT and a moates autoprom unit.
I have loaded the 6E xdf and 1227165_6E adx from tunerpro's website
The problem is whenever I try to datalog I get useless information and the number just start jumping sporadically.
This is a youtube video of the issue.
http://www.youtube.com/watch?v=SSstGLaLI1k
I have tried adding in a 20ms pause as I saw suggested for a similar problem on the tunerpro forums but it didnt help.
With all this being said, there have been a few instances where I did get good data out of the system but i would change screens and the it was back to this sporadic data again.
I would appreciate any help regarding this matter.
89 Iroc datalog sporadic data Help!
Have you checked for loose wires or connections on the ALDL connector or line between it and the ECM? Is everything grounded properly? With 6E (assuming your car is TPI and not TBI), once it gets a solid connection at 8192 baud, it should stay solid.
I checked the ALDL cable. seemed to be okay. I will check the rest of the wiring next. I briefly looked at it the other day and all the connectors seemed secure but I will look into that a little more. Thanks for the suggestions, and yes its a L98 TPI. Thanks for the suggestions. If all the wires are secure does anyone have any other ideas?
Thanks again.
Thanks again.
