speed density
Discuss DSM (Mitsubishi) definitions here
carlhunguss
speed density
Post by carlhunguss »
Do we have a working speed density outside of the ecmlink /JACAL stuff ? Im looking for the do it yourself setup? Hard wiring in the iat and map and a string of code? any thought or opinions? thanks guys
BrendanSmall
Post by BrendanSmall »
If it were possible to take a peek at the code after the SD mods, it'd be easy to implement. I've often wondered this too.
BrendanSmall
Found a nice forum about this today...
check out www.dsmecu.com
They have a speed density bin file, and xdf.
carlhunguss
sd works !
so its been a long time and three cars later . i have a new project now . its a 92 tsi . and i have done the speed density swap with a bin i downloaded from the dsmecu group it was written by a guy named nick sanders who i would like to thank . all those guy's in that site are on a high level. VERY intelligent. now for me its time to tune . so i would like to understand the ve tables and map scalar here in tuner pro . the car runs rich as it should for . a base .fat and safe . i have a 3 bar map sensor and my scaling is at 70.3% .
is there a good write up i could read ?
dose my scaling look write for the 3 bar ?
thanks guys for reading
p.s the car runs it just runs rich with stock injectors and cuts out as soon as it spools .
kaxlon
Post by kaxlon »
Make sure to check out the newest Swede Density for a better speed density software available at www.dsmecu.com
It's a total re-write and does not contain any residual MAF or barometer code.
.. KiM H .. aka KaxLon
