Map/hit tracing in Tunerpro RT
Jens Petersen
Post by Jens Petersen »
How do i enable the map/hit tracing (the mark) in the maps, so in can see where to make the changes?
I have used Tunerpro RT on an other pc with the same XDF, and there the map tracing where wissible, but i cant see it on my new laptop.
HP sels cars, Torque wins races
Jens Petersen
Re: Map/hit tracing in Tunerpro RT
Jens Petersen wrote:How do i enable the map/hit tracing (the mark) in the maps, so in can see where to make the changes?
I am using the Ostrich2 on a BMW Motronic 3.1 ecu.
Laptop shouldn't make a difference. If you can see it on one, you should be able to see it on another.
julian537
Autoprom hit/map tracing
Post by julian537 »
Is the autoprom capable of hit/map tracing?
No, the AutoProm cannot do address hit tracing.
