Moates I/O issue
JP86SS
Moates I/O issue
Post by JP86SS »
When saving a "read" of of an 29F040 chip, "save buffer to file" only writes 32768. The buffer has the whole file, just doesn't write it all out.
Went back to ver 310 to see if it existed there and it wrote the full stacked bin OK.
Probly something simple.
JP86SS
Found it
Post by JP86SS »
Buffer address range was incorrect by default.
Should be 07FFFF (not 007FFF)
Knew it was something simple just didn't see it.
At least that's an easy one to fix for a change :)
Currently only the chip addressing changes based on chip selection. The buffer addressing does not. The buffer addressing changes based on the size of a loaded file.
This is by design.
