Hello I have a bmw 318 model 1994 with Bosch Motronic 1.7 ECU 0261200950, after 20 minutes running the ecu takes high temperature burning hands. The ignition pulse measured with an oscilloscope is 18.5 ms at idle, in the 4 coils and 4 bases of driver transistors.
It may be normal? .
Someone can help me solve this problem or tell me where I may be wrong?
I read the file of the 27C256 eprom checksum is B0F32 will corrrecto? . Sorry, my English is bad.
Thank you very much
BMW 318IS problem
- ecuconnection
- Contact:
Re: BMW 318IS problem
angmar wrote: ↑Fri Oct 08, 2010 5:00 pm Hello I have a bmw 318 model 1994 with Bosch Motronic 1.7 ECU 0261200950, after 20 minutes running the ecu takes high temperature burning hands. The ignition pulse measured with an oscilloscope is 18.5 ms at idle, in the 4 coils and 4 bases of driver transistors.
It may be normal? .
Thank you very much
Do you have xdf file? Can you sent to me please
