log exporting in TP5
scott0999
Post by scott0999 »
When I goto export the datalog, it shows a list of 151 things to select that you want in the log
is there a way to make it export like it did in TP4, where you dont have to choose what you want?
if you want it to export everything, then select the top item, go to the bottom, press shift and select the bottom item. now press the right button and then they're all set.
scott0999
Post by scott0999 »
I dont really want it to export everything. I would prefer it worked just like it did before, or if you could preset it to work that way even
edit for typo
dfddfd2
Post by dfddfd2 »
I had asked Mark for this a while back. It's a pain having to go back through the list and re-select the items you want with every export.
Cheers,
Dave
scott0999
Post by scott0999 »
I would have to agree. bring it back, or give it the option please!
I've added this to the next build.
scott0999 wrote:I dont really want it to export anything.
Surely you do.
scott0999
Post by scott0999 »
Surely you do.
sorry that was a typo, I meant everything. but anyway regardless I would like it like before. I'm using a VE calculator spreadsheet thats setup for the way V4 exports.
I like the data tracing in V5, but the log exporting isnt working the way I would like
