New User E34 BMW w/ Motronic 1.3 179 DME...
I just ordered an ostrich 2.0 and have been playing with tunerpro in hopes that I can play around with my 535i a bit, and eventually tune for boost.
I see that the definition for this ECU the low load fuel maps only go to 50% and 6200 RPM and the high load fuel maps only go to 36% and 5200 RPM.
and with the ignition maps both only go to 36% and the high end of the RPM range is the opposite... Low load goes to 5200 and High Load goes to 6200.
Is this normal?
once beyond the parameters of the map does it just extrapolate or round down to the last cell? or does it switch to the WOT map?
Also... the rev limit is "151" how does that correlate to RPM?
thank you in advance for any answers you can provide to this noob!
Is this normal?
ah OK I see it now. so maybe the stock ECU with the stock engine just doesnt see more than 36% load??
So for example, if I changed the "Fuel High Load Map 1" (which has the same RPM for the top 3 values for some reason?) from:
10% 16% 20% 26% 30% 36%
5200
5200
5200
4800
4500
4200
3800
3200
2800
2600
2200
1800
1200
0800
to something with a higher max RPM on the map and a higher load % like this:
10% 25% 40% 55% 70% 85%
7000
6500
6000
5500
5000
4500
4000
3500
3000
2500
2000
1500
1000
0500
would this be recognizeable by the ECU? or is it not that simple to change the scale of the maps?
As I mentioned, I am very new to this, so I dont know how capable the program and the ECU are, and what is required on my part.
5200
5200
5200
4800
4500
4200
3800
3200
2800
2600
2200
1800
1200
0800
7000
6500
6000
5500
5000
4500
4000
3500
3000
2500
2000
1500
1000
0500
also... can I use the 173 XDF and Bin file in a 179 DME?
I know the maps will be off, but the 173 definition seems much more complete and has more support...
I assume you can because I have head of people putting a stock M20 (173 DME) in an M30 (179 DME) car and it would start and run... not very well, but it did work...
No it will not work this way. The ECU's are similar, maybe identical (because both Motronic 1.3), but the software is different (maps size and location, their axis values, constants, etc).
Anyway, in my opinion M30 engine management and boost are not friends.
You want either piggyback computer with additional fuel injectors. Or FMU aka rising rate FPR setup. Or some MAF/MAP conversion (with lots of headache). Or finaly stand-alone ECU.
bmwconnect
you will never be able to tune correctly with that XDF. It's nowhere near correct
BarrieM/// BMW Tuner
bmwconnect
NEVER USE A RRFPR . I have seen fuel leaks, fires, and injector failureJustin517 wrote:well right now I am still N/A and probably wont be setup for boost for a while, I just want to learn a bit right now.
I may end up still using an FMU/rising rate FPR and just use tunerpro and the ostrich to tweak the timing if I get some detonation under boost at certain RPMs.
Get yourself a set of bigger injectors
bmwconnect
A proper full XDF for the 535. PM for details
Re: New User E34 BMW w/ Motronic 1.3 179 DME...
In case anyone else is messing around with fueling on a M30 179 ECU:
The WOT FUEL map that needs to be edited for WOT fueling adjustments is mislabeled in the .XDF ("BMW_DME_179.xdf") that can be found at https://www.tunerpro.net/downloadBinDefs.htm#BMW. It is labeled incorrectly as "IDLE FUEL MAP".
I hope this helps someone else, as this was quite the pain to figure out.
Baltica
Hello. Tuners come here sometimes. Ask questions
