Different checksums on EEC-V reads
brianko
Post by brianko »
I'm trying to read a binary from an EEC-V ECU (99 Ranger). I've thoroughly cleaned the J3 connector, reseated the Moates adapter several times, and the reads aren't consistent. Often, I get a "verification failed" error when I try to compare the buffer contents to the ROM. I've done 15 different reads, and between them I get 5 or 6 different checksums.
Any ideas of what else I can do to ensure a good read? The problem is that I have a very limited def file to work with, so I can't tell if the binary is "good" or not other than to look for obvious code starts/stops with a hex editor. Pretty hit and miss, that.
--Brian
ExaTorq Tuning and Performance
<i>Performance for the Common Man</i>
972.276.2170/888.873.8012
http://www.exatorq.com
Some eec-v's reputedly require +Vbatt when reading them and cannot be powered from the J3 alone (insufficient USB power maybe?). I have not personally experienced this but it might be worth considering.
