BMW E46 M3 Speed Limiter
Clutch
Post by Clutch »
Hello, i'm new to this forum and i'm sorry if i'm posting in the wrong section this topic.
I'm bought a 2003 BMW M3 and i want to remove the speed limiter, normally i do all the car stuff by my self, i like to learn and do by my own.
Can somebody give me a clue what i need to do this.
Thanks in advance.
ecuconnection
Post by ecuconnection »
could be 250kph though I'm not 100%
www.ecuconnections.com DIY tuning forum
Clutch
Post by Clutch »
ecuconnection wrote:I didn't know there was a speed limiter on this car? I thought you were limited by the rpm only in top gear. could be 250kph though I'm not 100%
Yes this car have a speed limiter to 250kph :(
Clutch
Post by Clutch »
I have been searching and i think i start to understand how to do, the only thing i don't understand is where i can find the xdf file or see the location of the speed limiter setings.
Let me know if i'm correct:
First i download from the ecu the original data with galleto.
After i will open with tunerpro.
Change the value of the speed limiter (after i have the xdf file or creating a xdf with the location of the speed limiter setings).
Save the file with the modifications i have made.
Upload to the ECU the new file with galleto.
Am i in the right way?
Sorry my newbie questions but i have to start by some how.
Regards
I just want to learn.
Clutch
Post by Clutch »
Does this modification i want to do change the checksum value?
ecuconnection
Clutch wrote:Does this modification i want to do change the checksum value?
You will need to update the checksumm befor you upload the moded file or your ECU will lock up
