Bit logging
JP86SS
Bit logging
Post by JP86SS »
Hi Mark,
I know your hard at work on V4 so I'll throw this one out there.
Is there any way to graph bits along with data?
That would be cool to setup so you could see when functions/status changes during logging. Since the data is already there, it would just be mapping to the graph. (i'm going to be annoyed if this is already possible but haven't figured that out yet :) )
Things like PE/and AE, hiway modes, tcc on/off.
Might help with transitional issues and give some insight to tuning.
Jp
I'm not sure I understand. How would graphing a bit, which is either 0 or 1. Is there something more specific you have in mind? Bits can certainly be watched in the Flag/Bit window.
JP86SS
Post by JP86SS »
It seemed that when watching things like PE and DFCO flags would be nice to see a bit make a vertical line trace indicating when it came on/off while viewing the strip chart relating to another parameter. (Vss, TPS or MAP)
Saves jumping back and forth trying to find the exact point where the flag changed.
Just something I thought of when trying to locate where HIway mode was coming on/off in an old log.
cool.
thegig
Post by thegig »
It would also be nice to extract the data into a csv file so we can plot instances in conjunction with other readings.
Yeah, eventually I'll allow you to select exactly what you want to export to the CSV. It's a lot of work, but it will come eventually.
thegig
Post by thegig »
Thanks Mark. Your doing a great job. :D
JP86SS
V5 ?
Post by JP86SS »
Is this looking possible for the next rev?
If not I understand, you stated it would not be a simple change.
Just wondering what your outlook on this was.
The customizable CSV export is a lot of work. I've got it on the list for V5, but we'll see how far down the list I get before I decide to kick it out the door. It's still a few months out.
The bit "Graphing" is easy. You can count on this for V5.
JP86SS
Post by JP86SS »
Mangus wrote:The bit "Graphing" is easy. You can count on this for V5.
I figured the CSV would be trouble.
Bit graphing will be a nice option.
Jp
JP86SS
Back from the dead :)
Post by JP86SS »
I never realized that graphing of a bit was now possible.
Marks explaination here gave me the idea to try it and it works!
http://forum.tunerpro.net/viewtopic.php?t=3174
Create a "Value" for "Lockup' as one example.
Set the word to be the location in the datastream (In $8D = 0x36)
set low = 0, set high =100
Equation = "(X&01)/01"
From Magnus's Post...
the equation in the ADX Value would be:
"(X & <bitmask>) / <bitmask>"
where <bitmask> is the bitmask of the bit you're interested in, e.g. 0x1, 0x2, 0x4, 0x8, 0x10, 0x20, 0x40, 0x80, etc.
You'll now need to save and create the Lookup Table.
Insert new item...
Call it "BitConvert'
set 0=10, then add 1 = 90 (not 0 or 100 or it goes off screen)
Save.
Edit definition and set the output to go to the lookup table you just made.
Add the graph item to your monitor.
Save and run your log.
A line will now display indicating the status of the bit.
Good examples for uses that I'm planning are:
TCC Lockup, DFCO, AE, PE, Idle condition, Hyway fuel timer on/off,...
Lots of potential for honing in on transitional problems.
Thanks Magnus :)
Rhinoman
Post by Rhinoman »
I'll have to try that, it would be good to be able to log EGR on/off and closed/open loop, among other parameters
EagleMark
Post by EagleMark »
Im always going back and forth between monitor and item list frame by frame to see when a bit is set... can't beleive this is probably the only option I've never used or heard of in TP.
:D
JP86SS
Post by JP86SS »
Also after adding the item to the monitor and saving it, go back to the editor and change the line type to dots or dashes so you see it better than a solid line item.
stands out nicely on monitors with several items displayed.
Jp
