Porsche 944 Turbo HELP!!!
Supernotch93
Post by Supernotch93 »
I have a good .XDF and BIN I have been tuning with and all works great with that, however I cant get he TunerPro V5 (10/12/09 beta) to reconize my ostrich 2.0(v20.9.0, newest firmware) for the dash and adx side of things it says "Cable not found or not functioning(tested at 8192 baud". What am I doing wrong?!?! :(
Would anyone happen have an .ADS file for my car. Any help in this matter would help out greatly!! 1988 Porsche 944 Turbo (24pin DME)
Kris S.
TunerPro V5 & Ostrich 2.0
Post by Six_Shooter »
The Ostrich is just an EPROM Emulator. It does not have datalogging capabilities.
In GM applications, the Ostrich is used to replace the EPROM, and then another cable, such as the moates ALDU1, plugged into the ALDL port and then a second USB port on the laptop.
I'm not sure how you could datalog in a Porsche, but, you could try the data hit tracing that is found in TP RT V5. Unfortunatly I don't have any experiance with this, so I can't explain how to make that work, hopefully someone that has used it can go into detail on that.
Supernotch93
Well the cell tracing should be working but it sticks in just a couple of cells, just doesnt seem to be working correctly, are there any certin settings need for cell tracing to work with the Ostrish 2.0 that Im missing.. possibly in the definition maybe?
Kris S.
Do you have the latest firmware loaded to your Ostrich 2.0?
Moates.net has the latest firware version listed there.
Supernotch93
Yes I upgraded to the new 20.9.0 firmware and still dowdy seem to work correctly..
Kris S.
I'll have to give it a try, I'll reply with what I find, it will likely be a few days though, and I'll be testing it on a different ECM, not sure that matters with hit tracing though.
Supernotch93
Here is a dumb question.. My bin uploads seem to be working fine.. This is how i have my ostrich setup... I have the Bosch Motronic computer 24pin dme.. It has a 24 pin socket so i have the socket booster as Ostrich requires then its dip switch is set to 24 pin red strip facing pin one. next the on ostrich box i have both dip switches set to 28? cause if i set on to 24 pin and the other 28/32 it wont start? Do i need to be pin the 24pin dip switch on the ostrich box its self.. The Moates website doesn't seem to show this they only show the 1.0 internal dip switches.
(Ostrich 2.0 with Firmware 20.9.0 and TunerPro RTv500 newest release 10/12/09)
Kris S.
AZ_Speed
Re: Porsche 944 Turbo HELP!!!
Post by AZ_Speed »
Anyone have a copy of the OEM 944 Turbo 28pin DME .xdf .bin? All of my searches lead me to old dead links. Thanks :-)
