I am working with A GM ECU through Tunerpro. I have established communications with mode 1 for diagnostic chit chat. I would like to execute an EPROM dump with mode 2. Wondering if anyone has done this with Tunerpro?
Also, I know the ECU I am working with (diesel) supports mode 4 type functions where someone can reset the initial timing. I am not sure yet how to do this as there is not much info online about it. Does anyone know what I am referring to and how execute it?
Help on GM ecu mode 2 and 4. EPROM dump and message sending
- Six_Shooter
for one, I am just trying to learn the process but also because mode 4 is rather important for timing setups. This is also true for OBDII vortecs that require a tech 2 to set the timing up. Need to learn how to chat with the ECU and do small tasks.
I also do not have a burner just yet and wanted to ensure that we have all we need before doing that. Guess itwill make me feel better if I dump the EPROM from the diag port and get the same thing as what I get from my burner setup.
- Six_Shooter
- Six_Shooter
