ALDL Histogram
89 Iroc Z
ALDL Histogram
Post by 89 Iroc Z »
I would be great if you added a fuel histogram in your data logging interface. So you could see very quickly what cell on the VE table the ECM was in and what cells are rich and lean. It is a nice feature in datamaster but datamaster costs too much. It seams like an easy feature to implement in concept. This could also be taken one set further and a spark knock histogram could be made so you could see which cells in the spark table are causing knock.
Yes, this is on the list, and will be called "User Tables", where you can track any ALDL item in a table with axis being any other ALDL items (for instance, spark tracked against RPM and load).
No, its not easy to implement. ;-)
Look for this in the 4.X series.
