unable to edit BIN,730 ECM
blazbk
Post by blazbk »
Running TunerPro RT.
730 ECM
Useing S_AUJP_V2.bin with Super_8dm2-1.ecu
Got the BIN from thirdgen.org
I've studied the steps outlined in the HELP section of TunerPro.
The prob. is that after loading the BIN then the ECU nothing appears in the
Constants,Flags and tables.
I also just started using the Prominator.I uploaded the above BIn to the Prominator but I believe it has VATS in it.That's what I'm trying to edit in the above BIN.
The Constants,Flags and tables had been working before the install of the Prominator.But Since it's a totally separate program I don't see how this would effect TunerPro.
1971 Blazer with a 350ci eng. and a 92 S/D Tpi.
blazbk
Post by blazbk »
Played with it for a while and still nothing worked.
I erased my currant copy of TunerPro and downloaded the most currant version.
Works now.
Problem solved :D
good deal. I'm guessing there was something wrong with the original ECU file you were using.
