Injector Flow Rate
Injector Flow Rate
94 Chevy Suburban
383 TPI Vortec
Tow/Show
383 TPI Vortec
Tow/Show
- Six_Shooter
- Six_Shooter
I would use the size of a single injector. Usually the PW will be inverse of the injector size. The larger the injector constant put in the constant the short the PW will be.nrthrly wrote:Original set up was TBI, now TPI w/ 6395 ECM and 0D mask. Orig flow rate was 7.69, so now I'm thinking its the rate of 4 of the new 30# ers.???
I don't have my '427 (IIRC that is the service number that uses $0D in my possesion) set-up for use on my test bench to verify the functionality of the constants.
If you are too rich (especially at idle) then try adding the flow rate of the 4 injectors.
have you had this running yet?
I had trouble running MPFI from a '7747 ECM and believe it was due to the P&H injector drivers. I'll have to look closer at the late TBI ECM to see how it will work, this may be the ECM that will help some swappers that I talk with. Which is why I picked one of these up to play with.
I think it is the total rate per bank. The ECM has no idea how many injectors there are per bank, it is just thinking about total fuel per bank. That is the way mine is set up. Really to convert to TPI, they will often use the original chip, but then fudging the injector rate to shift the total fuel table into the right ball park. Then its just a matter of touching up the table. If you can, compare your BIN to one of the BINs online, and you will find the numbers are very similar, except for some minor compensation. I was just trying to make sense out of what I was reading in my chip last night. The constants were really weird, but the tables looked OK. Someone pointed out that I was using the wrong definition. (I was using $0D instead of $0E) Now things make sense, and I can see what was done and why.
Dave
daveinet wrote:I think it is the total rate per bank. The ECM has no idea how many injectors there are per bank, it is just thinking about total fuel per bank. That is the way mine is set up. Really to convert to TPI, they will often use the original chip, but then fudging the injector rate to shift the total fuel table into the right ball park. Then its just a matter of touching up the table. If you can, compare your BIN to one of the BINs online, and you will find the numbers are very similar, except for some minor compensation. I was just trying to make sense out of what I was reading in my chip last night. The constants were really weird, but the tables looked OK. Someone pointed out that I was using the wrong definition. (I was using $0D instead of $0E) Now things make sense, and I can see what was done and why.
Is the near idle table right.
http://www.fullsizechevy.com/forums/gen ... think.html
94 Chevy Suburban
383 TPI Vortec
Tow/Show
383 TPI Vortec
Tow/Show
