Who Needs An ADS or ADX?
- Six_Shooter
				hoursetraitor
mine is a f body but i would think the y body and any of the obd1 flash pcm would all be the same as far as issues. ive tried alot of stuff.
your typical innova obd1 can 1&2 code reader cant read these cars. thats what lead me to aldlcables usb cable and they send a nice lil starter cd.
datamaster worked great but not for codes. freescan is probably the simplest and easiest. efi live works somewhat and ive never been able to get either version 4 or 5 of tp to work tuner cat might have connected i dont remember but my trial expired. i really do like how this software is set up and how you guys are so into it. ill do whatever i can to help just tell me what you need me to do.
any chance of tuning my 92 ford(mazda) probe gt turbo with this software? you dont know how bad i hate hitting fuel cut when i spool up to 15psi,lol theres alot of guys on the probe forums and mx6 forums with stock turbo cars that would love this
				hoursetraitor
from what i can tell the cable works fine and the program it self can make changes to my stock bin and with that i can probably make a modified bin and flash it to my pcm with some other software. but tp isnt capable of communicating with my pcm at all as far as i can tell.robertisaar wrote:there is some ford support out there, but i have no idea about any of it.
we actually did manage some progress today with the $EE stuff, but no idea when it will be updated.
does it matter what bin im using?
im using your xdf and adx but the bin is from a unverified source. im geussing the adx is the issue? the post how to i follow seemed like that guy had it working no problem. i loaded his modified adx with the gauges and they showed up but no data stream:(
tuner cat has two definitions for lt1 cars just so you know one is called $EE and the other is $EEb some cars use b but most dont, i believe mine might be the b
				hoursetraitor
				hoursetraitor
				hoursetraitor
this one says crank volumetric efficiancy vs %th vs rpm
i can just email you my bin i scanned from my pcm would that be easier? or can it be sent that way? or is there a way to load it on the site?
i compared my bin to a few others and it was the same as one from 94 but not the same as one from 95. i know im actually looking at my bin which is pretty amazing to me. so with winflash i can read and save my bin, then edit it with tuner pro as far as i can tell and then save it and flash it to my pcm with winflash. but as far as tuner pro goes i cant use it with the car:(
of course i dont know how to tune anything or what changes to make but its just amazing the possibilities .
anyways if i have the $EEB i geuss the xdf def will work but will display funny?
Lucky is a moderator and Ford guru over onhoursetraitor wrote:any chance of tuning my 92 ford(mazda) probe gt turbo with this software? you dont know how bad i hate hitting fuel cut when i spool up to 15psi,lol theres alot of guys on the probe forums and mx6 forums with stock turbo cars that would love this
http://www.eagle-mark.com/Forums/viewforum.php?f=10
He has his own Ford section and could probably use the company.
				hoursetraitor
good to know... so if i want to make my trans sift sooner at wot do you have any advice? 5300 3-4 shift at wot seems and feels way too late and in my opinion its hard on these weak pos 4l60 trannys. i know its kinda complicated.robertisaar wrote:those look like believable numbers... so you have the correct XDF. if you had the wrong one, you'd see a large step at the beginning or end of the tables.
also, for screenshots, you can press the "print screen" button on your keyboard and paste into any image editor.
and why is my fan thing in celsius? and fan hysteria?? lol, whats that?
oh glennEFI i joined that forum about 2 days ago so ill check it out for sure. and while we are at it does anyone mess with the jeep 4.0HO say 91ish? i dont want more power i want better gas milage lol
				hoursetraitor
Yuo, saw you there!hoursetraitor wrote: oh glennEFI i joined that forum about 2 days ago so ill check it out for sure. and while we are at it does anyone mess with the jeep 4.0HO say 91ish? i dont want more power i want better gas milage lol
Don't think the Jeep is a hackable ECM. There are some things you cann do for milage but just normal tricks...
But I do have a 4.0L HO head for my 258 Scout. Along with that change will be a 2006 MPFI Tuned Port Intake Jeep made for a couple years there at the end, 2006 was last year for the 4.0L six cylinder engine. I have already checked ohms and electrical on injectors and TPS. It will run on a GM ECM. But it will be a ways off before I have time to put this together with a GM ECM. After that any Jeep owner could remove his Jeep ECM and rewire to GM ECM and have a tunable unit.
				hoursetraitor
yeah some of the early cherokees mid sizes were gm, gm 2.8l v6 biggest crap motor ever. alot of ac delco stuff on jeeps and motorcraft for that matter too. they used whatever. yeah my 91 xj isnt scanner friendly. you need a modis or brick to scan it. mega squirt is pretty appealing for my turbo car. but right now i lost my job as a tech so im just doing side work and who knows when ill have money for all these damn projects and somethings wrong with my camaro which is what started all this.GlennEFI wrote:Yuo, saw you there!hoursetraitor wrote: oh glennEFI i joined that forum about 2 days ago so ill check it out for sure. and while we are at it does anyone mess with the jeep 4.0HO say 91ish? i dont want more power i want better gas milage lol
high knock count, rev to 5k knock count goes up 100 or more 10-15mpg around town, feels like it has a hesitation or flat spot, will bog sometimes when i get on it now. brand new opti and water pump last month. im down to the following, failing fuel pump, plugged cat, bad knock sensor, failing coil or ignition control module. maybe the maf or map but i really dont know what the number should be when viewing live data, so thru it all i think i figured out how to tune my car but not what to change. i love this stuff
Sorry...robertisaar wrote:and here's where i say "stay on topic".
if you need something other than a GM OBD1 ADS/ADX built, please make a seperate thread.
- Six_Shooter
hoursetraitor wrote:yeah some of the early cherokees mid sizes were gm, gm 2.8l v6 biggest crap motor ever.
 There are MUCH worse engines out there. Granted it is was a bit underpowered, but made plenty of torque for the displacement and reliable as they get. I tried to blow my '85 2.8 up with over 277,000 KMs, and just wouldn't let go.There's also a LOT that can be done to them using all stock parts from other generations and some other engines to really wake them up.
Anyway, back on topic...
Are there still ADXs that need to be created? I thought Saar would have had them all made by now with the amount he's made.
Haw many have you made now?
To do a screen capture, press the "Prt Scr" or what ever is on your "Print Screen" button, usually in the top right side of the keyboard, open up paint, then either use the "paste" option in the drop down menu, or ctrl+v to paste the screen capture into the working area, where you can reduce the size, crop it, etc. Then upload and share just like you did with the pictures you did.
If you are talking of me Mark I have received 212 I believe. But that includes .ads .adx and .xdf defs.robertisaar wrote:i've made a LOT... but there are still plenty to go.
current statistics show that i have sent 175 streams to Mark, and from my numbers, i have a little less than 100 left.
EDIT: Question? The ads with names like A106.ads is obiously named differantly then say 42.ads obiuosly named after their bin file mask. Were these scantool data type information to start?
MM not MY.
i also believe i've sent you ADX files as well, i'm counting just ADS for that total.
A106 is a GM internal reference to a specific stream, not the mask IDs that lots of people have used to identify them.
since some streams apply to multiple masks, i decided to go by the GM numbering system with a list of vehicles it should apply to.
Well you have done a fine job providing us with useful def files and a personal thanks to you!
TunerPro has provided me with lots of fun as a gear head!
				hoursetraitor
i still want to get this to work with my camaro. i dont feel like giving tunercat money and i like this program better anyways. i geuss it could be my cable its from aldlcables.com its the usb one. theres no weird converter it just has a usb...somplace theres a chip embeded i dont know what it is, max? cable shows as functional and working when i test it. sorry for getting off topic complaining about 2.8 intake coolant leaks:P
i had the ALDLcables.com version for a while.... then it started acting flakey, and i cut it up to make my own table. their cable is indeed a 2-transistor setup, which doesn't work well with all laptops.
the 94-95 LT1 stuff is constantly being played with, and we made progress recently in another thread, just need to send out ADX files for testing to people with known good cables.
that will cover datalogging at least, tune upload/download may never happen for all we know. there are other programs out there that do it though.
				BackyardWrench
Newbie here...I would like an ADS for a '95 Olds Cutlass Ciera, 3.1L, w/ MAF, L82, A-body. I tried using the $1FA.ads and was able to connect, but all I got were a bunch of erroneously changing readings.
I did some searching and found "IsaacHayes" saying this to someone else with the same car on the 60degree forum..."The 1FA def for tunerpro is not the right one for your car. it's a bit miss-labeled and works on all the 3100's that have no MAF and are flash based. On the other non-maf cars you send a disable coms command, the ECM shuts up, then you send a connect command."
that's an old post, Isaac hasn't been on 60V6 much lately if at all...
http://www.tunerpro.net/gmOBDI.htm
what you need is the A263 file, which i haven't uploaded to Mark yet, but i do have finished.
http://www.wikifortio.com/780398/A263.ads
for now, this file will be here for the next week or so, then it will be deleted. i should be able to send the next batch of them to Mark aroud that time as well.
				BackyardWrench
				BackyardWrench
Bummer, same thing happens. I can get data acquisition working but with KOEO or KOER the values are just jumping around like crazy, ie. sitting still vehicle speed readings jump all over the place as do all the other values.
I'm using an ALDL to USB cable from ALDLcable.com and TunerPro RT v5.00.7575.00. All I really want to do is read codes and check sensor data.
BTW I learned about TunerPro from you over on W-Body as I also have a '95 Cutlass Supreme that right now has a shredded Reverse Reaction Drum in the tranny. Be prepared as I'll probably hit you up with questions when I start to re-build the 4t60E...LOL.
are you using V4 or V5 for this? if you're getting crazy values in V4, the problem is likely the cable itself, since i made that specific definiton for another W-Body member and he hasn't had any trouble with it.... then again, he's running a MAX232 cable that i made, not the flaky 2-transistor setup that the ALDLcable version is made from.
V5, could also be the cable, but datastream collision is also a likely possibility.
				BackyardWrench
Can you make an adx for the OBD1 Saturns from the info at this link?
http://www.saturnwiki.net/index.php/Data_Stream
here's a quick version, try it out and see if there are any serious problems with it. assuming it works well, i'll fill in the rest of the info and maybe some of the interesting mode4 commands.
http://www.wikifortio.com/698519/saturntest1.adx
if all you see are 0s, i'd venture a guess and say you don't have a BIN loaded. or at least not the correct one for your XDF.
a 7730 can run a LOT of different masks. you'll need to pull the BIN you have running now(if it seems to work ok) and then identify it, or just start over with a known-working and identified BIN.
what vehicle?
what vehicle?
