Entering negative values into ignition maps
charlescrown
Hello. I am totally new to TunerPro but like what I see. The problem I have is when I enter a minus setting into the ignition map it reverts to zero when I save it. Any advice would be appreciated. Thanks Dave
charlescrown
charlescrown
charlescrown
Yes your right with what you say. I an a member of Delco Hacking but waiting to get into the $12 discussion group. I have spoken with a friend of mine who says the same as you that maybe it cannot accept negative values. I am not concerned as the negs are only a few and in the low rpm range.
What I tried to do is enter all the same values for an EVO Lancer as my car is very similar but with a Delco system. That's where I found it would not accept negative values.
Thanks for your help and I will continue to see if it's possible.
