Fiat Punto GT XDF
zioweb
Fiat Punto GT XDF
Post by zioweb »
Hi everybody, I'm new there... buyed an ostrich and using tuner pro rt v5 to map a fiat punto gt... I also need the XDF for the Punto...
The map that I'm using is made with ECM2001, but I would like to emulate and live tracing with tuner pro to make a better work :)
Can you provide me an XDF or tell me where to get?
Thanks! :)
revlimit
Post by revlimit »
shure I got it, I am sending it to you, check your PM
zioweb
Post by zioweb »
revlimit wrote:shure I got it, I am sending it to you, check your PM
Thank you very much for your kindness :)
I'll waiting your PM :)
Thanks again :)
revlimit
Post by revlimit »
I have the XDF for 93 to 1999, yours is 2002, I don't have for that year
zioweb
Post by zioweb »
revlimit wrote:I have the XDF for 93 to 1999, yours is 2002, I don't have for that year
no no, mine is 93-99 version :) is correct :)
Punto GT from 2002 doesn't exists :)
revlimit
Post by revlimit »
you told me it was 2002
zioweb
Post by zioweb »
revlimit wrote:you told me it was 2002
no no, pheraps you're confusing me with another user :oops:
to be precise, my punto gt is '94 :) thanks again :)
revlimit
Post by revlimit »
post a picture of youe ECU, then post your BIN file. I want to see if it works
zioweb
Post by zioweb »
This is the photo of the ECU http://www.webalice.it/alice02/ecu.jpg
The bin file is here http://www.webalice.it/alice02/Gt099_140.ori
revlimit
Post by revlimit »
So that is your ecu? You did not just look for pictures on internet
zioweb
Post by zioweb »
revlimit wrote:So that is your ecu? You did not just look for pictures on internet
This is exactly the ecu installed on my gt. Number ending 099. And the file are on my private space.
What's the matter man? If you rellay have the DEF file for the Punto GT, and you want to share, I'll be grateful if you share it with me.
But really don't understand the story about me that says my gt is from 2002 (?!?!), GT's doesn't exists from 2002! Who said that? And now all his prolem to view the ecu. If you're in trouble with someone, this man is not me :) .
revlimit
Post by revlimit »
that ecu 099, what years does it cover?
zioweb
Post by zioweb »
revlimit wrote:that ecu 099, what years does it cover?
first GT model, from 93 to 95, without immo code.
To clarify, Punto GT's are three version:
1. 93-95 without immo code, ECU 099
2. 95-97 with immo code, ECU 841
3. 97-99 with immo code, ECU 159
For all the three version the way to modify the map are the same, so it could be one XDF for all the three version.
revlimit
Post by revlimit »
Yes I got the XDF , I tested all 3 bin files from different numbers it all works perfect. What is the idle ignition BTDC on these cars? 10btdc? 15?
checksum?
revlimit
Post by revlimit »
do you have any tuned files
zioweb
Post by zioweb »
I don't know about the idle ignition, I have some tuned bin, and there are no problem with the checksum.
can you share the XDF?
revlimit
Post by revlimit »
Post a tuned file I would like to compare it. Then I will send the XDF to tunerpro owner and he will post in the download section
zioweb
Post by zioweb »
revlimit
Post by revlimit »
Nice, there is a checksum, I just found it. I will put it into XDF so it calculates it automaticly
revlimit
Post by revlimit »
I just sent the XDF to tunerpro administrator so he will post it in the download section soon as he can
zioweb
Post by zioweb »
revlimit wrote:I just sent the XDF to tunerpro administrator so he will post it in the download section soon as he can
Good.
In the meantime I've written one by myself... curious to see your. :)
Cheers.
