bigger selection area around map points on graphs
delcowizzid
Post by delcowizzid »
I am about to start useing Tunerpro incar while on the move and have noticed its sometimes an effort to select points on the graphs even on the desktop without shaking round like in a vehicle is there any way to change the size of the selection area to make grabbing points easier.
Post by Six_Shooter »
Shift + Ctrl + Left Click, then "scroll up" to enlarge, or "scroll down" to reduce.
delcowizzid
chears mate that makes the graph bigger but doesnt make the silly little dot area any bigger so you can grab them easier if you know what i mean wound be nice if the area around the dot for selection was bigger say 5-8 mm circle
dfddfd2
Point selection radius
Post by dfddfd2 »
There is a "Point Selection Radius" field on the Preferences dialog. I haven't played around with it, but you might give that a try and let us know how it works.
Cheers,
Dave
delcowizzid
you little ripper just what i was after much better now thanks mate will work awesome now never seen that setting before LOL
Hmm, never noticed that before.
I can't say I really noticed grabbing the point much of a problem before.
I'l have to play around with this though.
