ALDL record/playback feature suggestions
omega
Post by omega »
There are a couple of items what might be beneficial on playback;
1. The possibility to search "Peak" values on sensor data. IE. fast-forward/rewind to peak point(s) on selected sensor(s).
2. The possibility to sort certain occurances (Knock input, etc) to certain inputs, such as LV8, BLM or such; possibly double-graphing LV8 on top of BLM cell number on top of Airflow reading. Would help out on maxing spark advances and doing MAF flow corrections on modified MAF sensors
3. As an additional item, preferences on displaying data on KM/h instead of MPH and Celsius instead of Fahrenheit would help :)
By the way, thank you for the excellent product.
1) yes, this is planned (but not listed)
2) sounds like you're referring to "ALDL Charts" which is also planned (and is listed).
3) Given you have the ability to edit the definition for whatever conversion calculation you like, this would be redundant (and difficult, considering all math that is done is user-defined in the first place and I'd therefore have no way of knowing that a particular item is displaying degrees F and can be converted to degrees C, for instance).
