closed loop.
monaro308
closed loop.
Post by monaro308 »
Hi Mark,
I'm currently running tunerproRT with an Ostrich 2.0 in my GM 5.0lt V8 (oz engine) and wanted to try tuning in open loop (no cats)but for the life of me i can not find the flag or constant like it's easily seen in the 165 and $6E.
Would anyone be able to point me in the right direction of where to disable closed-loop and how to adjust PE.
It is a SD setup similar to your 165 ECU.
Thanks for any help...mario
This is my set up:
$12def
BLCF5084 bin
16183082 ECU
Post by Six_Shooter »
There should be a "Min coolant temp to enable closed loop" or something similar. If you don't see a constant that has this, it may be missing from your xdf.
Having a complete hack of your bin file would help reveal this and show you what needs to be added to the xdf.
monaro308
Post by monaro308 »
Thanks Six_Shooter,yeah i 've had a look around with nothing obvious to me,but will keep playing around.
If you're bored...lol i can email you my bin and def and see what you come up with.
cheers and thanks again.....mario
honken
Post by honken »
Im not an expert on this but you have VE learn parameters in constant.
But the pe i cant help you with.
monaro308
Post by monaro308 »
Thanks honken, i'll try and see what i can find....
Cheers....mario
