29C256 Chip- Reading & Writting
Irocing
Post by Irocing »
Trying to read and write to a 29C256 I had programmed for me.
87 Iroc 165 ECM- Moates APU1 complete setup.
Tuner Pro RT program.
Chip runs great in the car, just want to make small changes.
When trying to read chip all I get is alot of garbage info-FFFFFF ect. ect.
Chip is showing 32K.
The 2 bins that come with TP RT, ARAP(Corvette bin I think) and another
one read correctly.
Running 6E XFD and tryed 32 & 32B No Luck.
What do I need to do :?:
APU1 set up correctly and Data Logging ect. work great!!
Just this problem.
Irocing
Cudda bought a Z06 with whats in the car.
SAD, but fun!
chip offset: 4000 to 7ffff
buffer offset: 0 to 3FFF
chip type, 29C256
Don't overwrite your chip accidentally!
Irocing
29C256
Post by Irocing »
Mangus,
Thanks, will try that :D
Thought possibly there was some encoded lock on the chip so you
couldn't read or write to it, if thats possible?
I paid to have it programed as a starter chip for my setup as I get up to
speed on this venture.
Would have been highly piiiii :x if had been the case.
Mangus, what would be the offset on a 27SF512 be if that occured?
I also made a couple copys of chip on 2 PCs just in case of Pilot error.
Thanks again, will post back if problems :wink:
Irocing
Irocing
SAD, but fun!
Irocing
29C256
Post by Irocing »
Thanks Mangus,
Finnally got to read the chip.
Total timing on the hot side and temps and idle off.
Made changes and saved but getting errors on programming new chip :(
Will read up on that link you posted and figure out how to double stack
if read correctly.
(BINGO) Lites went on, All is Well :D :D
:D
Irocing
SAD, but fun!
