Can TP be used to add a new table to 8D bin code?
ultm8z
Post by ultm8z »
I'm assuming that modifying the XDF file to add a new table doesn't necessarily add it to the bin code? Rather, by adding a new table in the XDF, the table has to already exist in the bin code?
For example, in 8D.... if I wanted to add a new Accelerator Enrichment table that varied delta-MAP AE vs engine RPM, can I simply add that in the XDF? Or does that table have to already exist in the 8D code before I can modify the XDF to display it?
_____________________________
1971 Pro-Touring Camaro
GM HT383 shortblock, MiniRam manifold, AFR heads,"8-speed" transmission (700R4 + Gear Vendors OD)
Self-Tuned 7730 ECM
PM me about tuning your 7730 ECM
Re: Can TP be used to add a new table to 8D bin code?
ultm8z wrote: Sun Dec 14, 2025 5:20 pm Or does that table have to already exist in the 8D code before I can modify the XDF to display it?
This
ultm8z
Post by ultm8z »
Shucks...
Thanks for the reply though.
Self-Tuned 7730 ECM
