Does it have these features?
dikidera
Post by dikidera »
I am new to the tool. I want to ask if the latest Tuner Pro has the ability to revert changes I've done to maps? Or being able to copy parts of one map and place them onto another, including Row or Column values.
nomecone
Re: Does it have these features?
Post by nomecone »
There is some undo ctrl+z functionality in the editor windows. It is best to keep your own bin file versions saves so you can restore if needed. TunerPro is an editor, I do not think version control is in its scope. Github is one option for keeping versions of bins with the same name. It can keep track of every small change to a file if you are looking to do full version control.
You can copy and paste parts of or whole maps in TP, you can also copy paste row and column values.
dikidera
Post by dikidera »
I personally believe when it comes to tuning, it is normal to have some history so that you can see what your previous value is. Especially when dealing with multiple maps or a complex tune, it is easy to forget if you have or have not changed a value OR what the previous value was and thus what the difference is between new and old.
nomecone
Post by nomecone »
There is also Tools>preferences>general [X]Enable Edit Logging
it makes a log file of all changes made to a BIN file
