Import/Export
idadbg
Import/Export
Post by idadbg »
Are you planning to make an interface for accessing changing or adding parameters from the TPPlugin?
My experiment in this: https://youtu.be/olODYx6f2qU?si=E4r1byHM2hM3NnwE
Re: Import/Export
Is it your intent to add your CSV importer to TunerPro? If so, I'd be happy to use your code as a reference to potentially add this functionality natively.
DrInfinity
Re: Import/Export
Post by DrInfinity »
Is it possible to add copying the table to the Windows clipboard along with the axes, and leave the insertion without the axes?
Re: Import/Export
DrInfinity wrote: Tue Aug 26, 2025 10:02 am Is it possible to add copying the table to the Windows clipboard along with the axes, and leave the insertion without the axes?
Sure, but why did you ask here in an unrelated thread?
