413 vs 506 bin knock Correction
Sinbad98
Post by Sinbad98 »
Hi Guys,
I‘m new in tunerpro. I want to use the 506 bin on an 413 red Label. I don‘t know anything about how the knock correction on this ecu is working. Is the knock correction still working if I use the 506 bin on my 413 red label?
Tank You :)
olafu
Re: 413 vs 506 bin knock Correction
Post by olafu »
506 and 413 has differences in knock control parameters, because bore and stroke are different, but otherwise it's not a problem to mix these bins. Use 506 or 413 parameters depending on which engine you are using.
