Copying Entire Table Contents Freezes TP
tightmopedman9
Post by tightmopedman9 »
This issue started in build 5.00.9237.00 - I believe it is related to the upgrade to Visual Studio 2019.
If I try to copy the values from one table to another, and select the first entry in the table to which the values are being copied, the values will slowly be entered one at a time. For a 16 x 16 table this takes about 45 seconds. If I copy the values from one table to another, but instead have the entirety of the contents of the recipient table selected, then TP will freeze.
I live a lot of the features and bug fixes included past .9237, but I have to use build .9209 because I copy values between table so frequently.
Zigmund
Re: Copying Entire Table Contents Freezes TP
Post by Zigmund »
Yes! Same thing! Why is that?
Zigmund
Post by Zigmund »
Installed previous version. Copying is fast as before now!
Chatchai
Post by Chatchai »
solved please check in latest build .9513 version on download page
This should be resolved in the latest build. The issue came up as a result of adding auto-coloring of table cells. I've since optimized the behavior.
