New member- Tunerpro versions?
rhubarbray
Post by rhubarbray »
Hey all, I have a Ducati motorcycle that I need/want to tune to get rid of the stumble at low throttle openings. I've seen videos of others using Tunerpro with great success and much hard work. The video I saw mentioned he uses TunerPro RT. Now, I have only 1 bike that needs work so do I need TunerPro RT or can I use TunerPro? Are there any limitations or drawbacks of one over the other?
cheers,
Ray
Re: New member- Tunerpro versions?
The main difference is that if you want to do real time tuning then you will need to use the RT version. Here is a summary of the additional features TunerPro RT has: http://tunerpro.net/features.htm
