needed ecu definition file for mk4 vr6 12v 01 (021-906-18R) me7.1
jaremyhawk
Post by jaremyhawk »
hey guys trying to update my 2step map my tuner made and for some reason it wont activate... he says engage 1st pump the clutch 2 times then hold at 4300 rpm tried that multiple times and it wont activate (verified clutch switch is working ) hes asking for $100 cdn to take another look... so i call bullsh** because it never worked... the pop and crackle is stupid aggressive though i just need someone to locate a xdf or bin file or make one any help would be much appreciated.. theres no ecu definition on the tuner pro website unless its the same for the AAA motors :? thanks guys not sure if i should attach the stock file as it says invalid file
heres my email if you want the stock map: jaremyhawk@gmail.com
jaremyhawk
Re: needed ecu definition file for mk4 vr6 12v 01 (021-906-18R) me7.1
update heres my file...
01 mk4 vr6 5spd stock map.org.rar
(196.96 KiB) Downloaded 769 times
