FNG needs a lot of help getting started with Tunerpro RT
Hi,
My car is a 95 Buick Riviera supercharged V6. I'm told that the car uses OBDI software but with a OBDII cable.
After researching this on a Riviera Performance forum I bought an ALDL OBDII cable with a usb port to connect to my laptop running Windows 7.
I can't seem to get the Tunerpro RT software to run. Here is what I've done so far.
Downloaded the drivers for the cable from the CD that was provided.
Downloaded Tunerpro RT and the following definition file for my car 5b_TPV5.xdf.
Verified the com port being used, and did the cable test on Tunerpro which was successful.
It looks like I have Tunerpro connected, but when I plug in to the car and turn the key, it says hardware not found and not ready. How do I get Tunerpro Rt to start reading codes and sending engine data?
I admit to being an idiot on this stuff, I don't know what bins are and don't understand a lot of the terminology I'm seeing.
I have a service engine light that I want to read. Really appreciate help getting started.
launch tunerpro
click Acquisition->Load definition file and then select the ADX for your car.
if you have the correct COM port selected, either press Ctrl + F4 or click Acquisition-> start/stop data scan.
the bar in the bottom that is/was yellow should now turn pink for a short amount of time while trying to connect, then blue when it does connect.
First let me say I REALLY appreciate you trying to help me on this.
My screen just shows compare and tools, no acquisition button.
I think my problem may have to do with the .adx and .xdf files I downloaded from the website. When I try to open the xdf file I get a message that its an invalid file. I downloaded $5b files from the list on the website. The way I downloaded the files was to right click on the file name and then click on save link as...
In tunerpro I went to file open bin and then selected the .adx file that I downloaded. That seemed to work ok because I see that file name up at the top of the screen then next to it says no XDF selected. Then I click on XDF button and click on open XDF and then select the file I downloaded. That is when I see the invalid file message. I am thinking that I need to have an XDF loaded before I can see the acquisition button.
