Moderators: robertisaar , dex
TGPilot
Posts: 21 Joined: Wed Nov 30, 2005 5:47 pm
Post
by TGPilot » Tue Feb 19, 2008 6:51 pm
Hey Mark,
Wondering if you have an ALDL to show Floating Point for $0D?
-Kenny
Posts: 1926 Joined: Wed Mar 19, 2003 1:49 pm
Post
by Mangus » Sat Feb 23, 2008 9:24 pm
Floating point?
TGPilot
Post
by TGPilot » Sun Feb 24, 2008 9:18 am
The floating cursor in Tuner Pro RT to show the load point. In $0D it does not have a kPa selection for the X-Y axis. I can see the cursor, but it is hung-up on RPM only.
Post
by Mangus » Sun Feb 24, 2008 9:34 am
Data tracing. (Floating point is a mathematical term, hence my confusion).
I don't have one premade, no. but you can set this up yourself! (This is one of the beauties of TunerPro, right?)
There's a good post over on TGO on how to do this (my docs are a bit out of date in that regard).
TGPilot
Post
by TGPilot » Sun Feb 24, 2008 12:38 pm
I will do some searching there.
Thanks Mark!
honken
Posts: 111 Joined: Wed Dec 15, 2004 6:05 am
Post
by honken » Tue Feb 26, 2008 8:16 am
In tunerpro mark the table you want to trace.
Then xdf/view/edit item info (f2) at the ALDL Assoc you enter a X and Y axis
If i remember right the rows and colmns need to be floating point
Post
by Mangus » Tue Feb 26, 2008 8:30 am
honken wrote: In tunerpro mark the table you want to trace.
Floating point or int.
TGPilot
Post
by TGPilot » Tue Feb 26, 2008 8:35 am
Honken...I did that. RPM one axis and then for the other you need kPa to show load. $0D does not have a "kPa" selection.
honken
Post
by honken » Tue Feb 26, 2008 2:07 pm
TGPilot wrote: Honken...I did that. RPM one axis and then for the other you need kPa to show load. $0D does not have a "kPa" selection.
Its map you need for engine load vacum.
TGPilot
Post
by TGPilot » Tue Feb 26, 2008 3:09 pm
Honken...I found this on 3rdgen from you. I entered the values and wah-lah she be workin' man!
http://www.thirdgen.org/techboard/diy-p ... pa+convert
If you (Honken), Mark, or Craig Moates is ever in Colorado Springs I owe you guys a hell of a night on the town!!!
