Bosch ECU - Problem with Row Labels
ipejasinovic
Post by ipejasinovic »
Hi,
I tried to develop a XDF file for some Bosch ECU from Audi, but I have a weird problem. I can't populate Row Labels right because some strange Bosch function. I need get RPM values from bin file and this is how Row labels should be populated:
Row[1].Label = (Bin.Value[ADDR] + 0D) * 40;
Row[2].Label = (Bin.Value[ADDR + 1] * 40) + Row[1].Label;
Row[3].Label = (Bin.Value[ADDR + 2] * 40) + Row[2].Label;
etc...
Is it possible to this in TunerPro?
BTW, this is what "Eprom, subtract" option in WinOLS does.
Laimis
Post by Laimis »
You can always write axis values manualy..
yoda69
Post by yoda69 »
This is a similar problem to what I've been having in some Aussie GM ecu's. I've added it into the feature suggestions http://forum.tunerpro.net/viewtopic.php?t=2088, hopefully the more people requesting it, the more chance we have of getting it. In the meantime I have been manually configuring.
yoda69
ipejasinovic
@Laimis
I can manually enter axis values, but I'm not sure are they same for each car with that ECU.
@yoda69
Yes, it's similar problem.
Post by robertisaar »
i believe this is what the "internal, pure" labeling option is for, no?
ipejasinovic
Yes, for reading data from binary file, but that data isn't just representation of RPMs for e.g. That data are some increments and how to use them, I described in first post.
BTW, here are screenshots. Same map in WinOLS and TunerPro.
Wrong axis (TunerPro)
Good axis (WinOLS)
yoda69
Post by yoda69 »
I tried this, but from what I can see, it starts at a given address then goes forward or back so many bytes to the next address, it doesn't actually add to the first value. The ones in mine are a little more complicated as I have a start address + constant for the first table, the second table then starts off where the first table ended, and so on up to Table 8. I'll send Mark some detailed info of what I'm trying to do, butunderstand that there are many more other features that he is working on that are probably more important.
yoda69
revlimit
Post by revlimit »
Pejasinovicu pickin dusmanine!
Tunepro does not support Bosch program scale labeling calculation, you will have to calculate them yourself and insert them in manualy. I made most of Bosch XDFs on this forum.
ipejasinovic
@revlimit
Znamo li se možda?
prj
Post by prj »
Because TunerPro uses XML, you can write (I did...) a program that will parse the map table and add all tables in the ECU with axis values to the XDF. You can even transform those axes...
The ability to do this kind of math is comiong in the next week or two.
prj
Post by prj »
The math engine was updated, but every way that I come up with to do this in axis math crashes TunerPro.
There just seems to be no way to reference the calculated value of the previous or the next cell.
CELL(INDEX()+1;FALSE) or CELL(INDEX()-1;FALSE) both crash TunerPro.
SUM() can not be given an address range (like in excel), so that doesn't work either, else I could do 256-SUM(INDEX() to INDEXES()).
IF together with CELL crashes as well.
So, how do I do this? Is this even supposed to work? I can't reference the previous or next column (which should be calculated by now) and I can't sum a column range either.
I use this algorithm to do this in Java:
Code: Select all
int prev = Constants.AXIS_END;
for (int i = data.length-1; i >= 2; i--) {
   int value = prev - data[i];
   values.add(0, convertValue(value));
   prev = value;
So if I can't sum this and can't do it recursively, how am I supposed to do this?
Only way I can come up with is a huge nest of IF's.
IF(INDEX() > 1;IF(INDEX() > 2;...;X-SUM(CELL(INDEX()-1;TRUE);CELL(INDEX()-2;TRUE));256-X)
That doesn't seem very pretty though.
Use per-cell equations.
First cell is: (256 - THIS()) * 40
All other cells are
CELL(INDEX() + 1) - (THIS() * 40)
prj
Post by prj »
Mangus wrote:Use per-cell equations.
All other cells are
How do I use a per-cell equation for an axis?
Do you mean that I have to create a table for each axis and then link that table as the label source?
That works, but seems a bit cumbersome.
Sorry, forgot I hadn't added that yet. Create a 2D table with per cell equation. Then link the table for the appropriate axis in the tables that need it.
Fpr a row-wise table, all other cells are
CELL(ROW() + 1; COL(); FALSE) - (THIS() * 40)
Col-wise table would be
CELL(ROW(); COL() + 1; FALSE) - (THIS() * 40)
prj
Post by prj »
Yeah, that I know how to do.
It will just be annoying to create tables for each axis, but since I generate the XDF anyway, I can do it programmatically.
prj wrote:Yeah, that I know how to do.
Why is it any more annoying than defining the axis for the table that it's part of?
Also, the point of creating a table representing the axis is for the user to be able to modify the axis. This is why the axes are embedded in the first place.
revlimit
Post by revlimit »
ipejasinovic wrote:@revlimit
Znamo li se možda?
Pejasinovicu ostavi tunerpro nemas ti pojma!
Mangus nice work, you are great
prj
Post by prj »
Need to change my XDF generator more :P
Yeah, I understand. The cool thing would be if you chould change axes right on the table and define them in the same place.
But nevermind, It's good there is some kind of solution to rescaling the axes inside tunerpro now.
prj
Post by prj »
I finally got around to testing this.
It doesn't work properly.
I can make the axis values get calculated, but if I change one value all the other ones change as well.
I see why this is programmatically, but it makes the entire feature completely useless, so we're back at square 1.
Of course it changes the others - the whole point of this axis design is that it cascades. Each cell uses the preivous cell's values.
prj
Post by prj »
Mangus wrote:Of course it changes the others - the whole point of this axis design is that it cascades. Each cell uses the preivous cell's values.
Yes, but that makes it completely useless for editing.
You don't want to change all axes usually - perhaps the 2-3 last ones.
I am changing one value - I don't want others to change.
As I said, I perfectly understand why it is, but it makes tunerpro completely useless at editing these axes.
It's easier for me to do it in excel.
Then consider using Excel.
prj
Post by prj »
Mangus wrote:Then consider using Excel.
Sure, that is not an issue at all.
Don't take this wrong, I am not trying to whine or anything, just saying that if you want to change the axis parameters, then it is currently not really feasible to do so in TunerPro.
I don't really mind, since I don't edit my XDF's by hand anyway.
