For more information on the AutoProm check out the Moates site at:
http://www.moates.net/apu1-autoprom-pac ... rsion.html
Basic need for the extra channels is to log your wide band O2 sensor in same log file. But with three channels you can run a wide band O2 sensor for each side of a V8 engine and still have one left over for extra IAT/MAT sensor to measure before and after boost air temps!
So lets start with the APADC wire inputs, looking at back of AutoProm they are Channel 3, Channel 2, Channel 1 and Ground next to the USB cable. If you have a wide band O2 sensor setup already with a gauge or data log cable you can run a ground wire from same ground lug on engine block into car for use with the AutoProm, one ground will cover all three circuits.
Load your ADX data logging file in TunerPro and click on Acquisition, Edit Definition.
Or the 2 gears to Edit ADX.
First thing we have to find is the payload size. Under commands look at Data Transfer for 160 Baud ECM.
Or usually Mode 1 Message 1 for 8192 Baud ECM/PCM.
The AutoProm adds three channels on top of this Payload. For the Payload size of 63. Have to count from 0 so 0 to 62 is the 63, the last byte used in ALDL data stream is 62.
For 63 Byte Payload the AutoProm Channels will be:
Also the channels on the AutoProm are not in exact order of data stream.
Channel 1 is 65 and 66
Channel 2 is 63 and 64
Channel 3 is 67 and 68
This was done and tested in $0E-16197427-V1-72-IH.adx file on my sons 72 IH truck.
We will use the Payload size of 20 for the rest of this example ( have to know your Payload size from existing ADX file, see above). Have to count from 0, so 0 to 19 is the 20, the last byte used in ALDL data stream is 19.
We will be using 16 bits for source data for each channel of AutoProm. Each Byte has 8 bits. So this is 2 Bytes or 16 bit per channel on AutoProm.
Remember the channels on the AutoProm are not in exact order of data stream.
Channel 1 is 22 and 23
Channel 2 is 20 and 21
Channel 3 is 24 and 25
This was done and tested in $42-1227747-V4.3.adx on my 1990 Suburban.
So lets get some values set up for the three channels of the AutoProm! Open values.
Then Add New Item.
Add new item information.
1. Title of what the channel will be used for.
2. Unique ID, if it is same as something already in ADX it will prompt you that the ID is not unique.
3. Description of what the channel is for and can keep your conversions here, notes or whatever you need!
4. Set Data Type.
5. Set Stock Units.
6. Set Units Display.
7. Packet Offset to Channel 1, Packet Offset is 22 in this case. TunerPro will automatically fill in the Hex address in left box.
8. Source Data for AutoProm is 16 bit.
9. Range low will be 0.00 and Range high will be 5.00 for 0 to 5 volts.
Now we need to set the conversion. Information coming in is Analog then converted to 1024 bits Digital, we want to convert that back to the analog reading of 0 to 5 volts. Click on Conversion Tab at bottom of value window.
Then click on the Set button.
The AutoProm Channels are 1024 bits! This is 4 times as much resolution as the stock ECM/PCM which usually uses 256 bits. Since we are using 16 bit/2 bytes we need to do the math and TunerPro is already set up for this! Remember it is Byte 22 and 23, we set it for 16 bit.
Byte 22 is MSB, Byte 23 is LSB. The equation is MSB * 256 + LSB = Value (Value / 1024) * 5 = 0 to 5 Volts.
Lets do it back wards so you can see how we come up with the equation. 5 volts (is the value coming in as Analog) divided by 1024 bits (Digital) that the AutoProm uses equals 0.0048828125. So if the AutoProm see's 1024 bits times 0.0048828125 it comes out to what we want to see in volts, 5.0
Conversion for 0 to 5 volts is:
(X * 0.0048828125) + 0.000000
The + 0.00000 is for offset, it is not needed right now for volts but later you will see how it works for Air Fuel Ratio (AFR).
Add the conversion and click OK.
Click Save to save your new value to your ADX file!
Since we set up a new value for AutoProm Channel 1 volts which can be used for anything, but in this case it will be for Wide Band O2 sensor so lets set up a second value for AutoProm Channel 1 AFR. You can have 2 or more values for same Packet Offset to show different values. With the Wide Band O2 sensor it is great to see that the volts are correct for setting up the Wide Band O2 controller, but what we really want to see is the AFR, Air Fuel Ratio!
For getting proper AFR you have to set up your Wide Band controller for 0 to 5 volts. Here's an example of the Wide Band software and settings for Inovate LC-1 Wide Band O2 controller we are using below. You can skip this for now if your not ready and continue with setting up the value. Then come back and adjust to your Wide Band O2 sensors readings in the value we are creating in TunerPro.
So lets add another value. Click on Add New Item just like last time and we will set it up for AFR.
4. Set Data Type.
5. Set Stock Units.
9. Range low will be 7.35 and Range high will be 22.39 (TunerPro will truncate to 22.3899 which is fine) for the LC1 Wide Band O2 Sensor. Other sensors may have different values.
10. Set the Alarms for whatever you would like for low and high, click Enable.
Click on the Conversion Tab at bottom.
Then click the Set button.
For the LC-1 WideBand 0V = 7.35 AFR and 5V = 22.39 AFR.
AFR of 7.35 to 22.39 is a difference of 15.04 divided by 1024 = 0.0146875
Conversion for this would be:
(X * 0.0146875) + 7.350000
Adding the offset makes 0 volts 7.35 AFR
For other Wide Band controllers that have 0V = 10.00 AFR and 5V = 20.00 AFR.
AFR of 10.00 to 20.00 is a difference of 10.00 divided by 1024 = 0.009765625
(X * 0.009765625) + 10.00000
Adding the offset makes 0 volts 10.00 AFR
Rinse and repeat for AutoProm Channel 2 and 3!
Here's a shot of the dash board in TunerPro looking at all three channels from AutoProm. Channel 1 has Volts and AFR. This was done on my test bench with 1.5 volts going into all three channels.
Notes: Probably the most important part of setting up three channels on the AutoProm that makes it hard to get the channel correct is a few details.
1. AutoProm Channels are not in order of ALDL packets. Look at the first picture of this thread.
If the ALDL packets were in order of the channels it would be: 3 | 1 | 2 | Ground.
2. AutoProm Channels are 16 bit, so you need 2 ALDL packet offsets. If you don't get them correct your reading is not even close but you will still get a reading!
2. With nothing hooked up to the three channels you still get some readings. (see 3.)
3. ADCs are very sensitive. When you connect something to one of them, you drive the signal to a known state. The way the ADCs on the APU1 are done on an electrical level allows them to float a little, which means that they are quite susceptible to picking up noise from other channels. If you want the noise to go away, tie unused channels to ground or just ignore signals on other channels.
4. When signal going into a channel is set up correctly to ALDL is extremely accurate! I tested signal going in to what is displayed and it is perfect to .00001 with Digital Volt Meter. But because of notes 1, 2 and 3 can be very hard to diagnose.
Special Thanks for technical information for this article to:
Craig Moates http://www.moates.net/
Dave Blundell http://www.moates.net/
Mark Mansaur http://www.tunerpro.net/
gregs78cam http://www.gearhead-efi.com/
Keep an eye on this page and if any mistakes are found or more information can be added it will be updated here!
Stay Tuned! :rockon:
EDIT: Notes to date:
1. 160 Baud $42 shows on dash but does not show up in data.
2. 8192 Baud $0E-D shows in all three gauges in dash and records first two channels.
